Stiff Knuckle D60
Discussion in 'The Garage' started by txfireman110, May 1, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Being new to this axle, I don't know what to think /forums/images/graemlins/dunno.gif
    The passenger knuckle swivels easily, but doesn't have any play so I assume this is good, but the driver side knuckle is EXTREMELY stiff. It takes quite a bit of force to turn it back and forth. Any suggestions as to the problem?
    Also, the gear oil was thick and gray? What's up with that, or is it just water in it?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I would assume a bad lower bearing, and or no grease or very old grease that has dried up and became stiff.
  3. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Are the shafts still in it? If they are it could be a bad u-joint like mine.
