stiff throttle TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazenwhip, Apr 30, 2005.
  1. blazenwhip
    blazenwhip 1/2 ton status
    Mar 14, 2005
    440
    Phoenix
    My throttle is stiff on my TBI. I have to push more than what feels normal. I've disconnected the throttle cable and it moves freely with no resistance. I'm thinking the problem lies with the tension springs on the TBI itself.
    It's dangerous on the trail when i need to give it just a little gas. Right now it's too much gas at once. It's like it makes the truck overshoot an obstical that i need to go over nice and slow.
    Any suggestions, ideas or comments?
  2. Bob87Burb
    Bob87Burb 1/2 ton status
    Apr 19, 2003
    141
    RI
    Mine is the same way. I lubed the cable, took off the bracket for the gas pedal and cleaned that up and lubed it, and finally swapped out TBI units. I even sprayed the throttle shaft on the new unit, and it still feels the same. I don't trail the truck, but I know what you mean about just wanting a little gas, and getting a lot. In my case, I think it's just the way it's set up. My buddy's pickup feels the same as mine too. Maybe someone makes lighter springs, or the stock ones could be modfied to be lighter?
    In your case, have you checked the bores to make sure they're clean? Sometimes crap builds up there, causing the plates to stick a little.
  3. blazenwhip
    Mar 14, 2005
    440
    Phoenix
    I've done all that you have done too. Thanks for your input.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    New cable...
    A groove wears in the cable. The friction is only high when there is tension on the cable and it sits down in that groove and wears on the casing instead of the teflon liner. You can prolong its life by twisting the cable so it wears on another surface but it's a bandaid fix.
  5. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    My throttle is the exact same way. It is extremely annoying!! I also tried all the lube tricks, didn't work. If someone tries a new cable, post up with the outcome.
  6. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    same thing with the last to chevys i had, my blazer and c10, sounds like a common problem with out a common fix :confused:
    if anyone figures out how to fix it completely post it up im interested to see how ya did it.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    That's some funny sh¡t right there.
    I told you what the likely problem is.
    If you don't believe me, have a monkey (or your Mom) pull on the throttle body end of the cable (with the cable unhooked from the throttle body, duh) while you operate the accelerator and you'll notice it behaves the same.
    It'd also be a good time to see if the throttle body is wore out around the throttle shaft. If it is, it'll cause binding and a wicked vacuum leak.
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You need a new cable. $15 from Autozone and 10 min. to install it. I had the exact same prob. w/ my '87 burb. A new cable fixed it. They wear a groove inside the sleeve and start to fray over time.
  9. blazenwhip
    Mar 14, 2005
    440
    Phoenix
    that is funny. I'm still laughing!
    Thanks. I'll try it in the morning.
  10. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    they sell them at autozone? i've got the same problem, i think i'll give it a try.
    tho i think my truck's got the same problem with the TV cable. if i disconnect the TV cable from the TBI, the pedal is much easier to push. if the throttle cable doesnt fix it i'd try replacing the TV cable.
  11. blazenwhip
    Mar 14, 2005
    440
    Phoenix
    It worked!
    Holy Crap! It worked! A couple of twists and whammo! It feels like a new truck again. Thanks man!
  12. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    cool :waytogo:
    did you just twist the cable so its riding on a new spot?
  13. Bigg R
    Bigg R Registered Member
    Feb 21, 2005
    34
    Martinsville,Indiana
    You can get a carburetor spring kit in the HELP section of most part stores and find one that is slightly weaker than the TBI spring,hook it from your CC shaft to the throttle/TV cable bracket(should be a hole on right side..facing engine). This will make the throttle easier to operate till you can get a new cable!
  14. blazenwhip
    Mar 14, 2005
    440
    Phoenix
    yup. the outer black part that the cable travels thru. I twisted it about 180 degrees.
  15. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    just came back from autozone, dont have it. they never have anything like this at my local stores, maybe your area is different.
    guess i'll try twisting the cable. i was gonna do this in the first place but its so stiff i figured i'd just replaced it, owell
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    OE cables don't cost much more from the stealership and will last a lot longer. I've ruined quite a few of the cheap auto parts store ones.
  17. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ya, i dont like going to the dealers around here. when i tell them i need parts for an 89, they give me funny looks. they think 90's vehicles are old.
    anyhow, i went to autozone.com and looked up the part on thier website.sure enough, they had it. infact, they were the only autozone in my area that had one in stock. so after calling to confirm, i had to drive back across town to pick up the part. stupid parts counter people. from now on im getting all my part numbers online then going to the store.
    oh yea, throttle works awesome now. i couldnt believe it helped that much since the old one slides so easily. definatly reccomend it to anyone who has the stiff throttle TBI blues
  18. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I have a 90 K-5 that I think has the same problem but I want to say that when I depress the accelerator slightly it seems to hesitate until I depress the throttle harder then it seems to get fuel and run ok. I’ll try replacing the cable and see what happens. Ant thoughts on this?
  19. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    this is the only way to go for any part. you must find and verify your own part ##s the wal-mart/mcd's culture we live in has allowed pride in ones job to be forgotten, most of your average commercial parts houses will hire the least expensive person, the knowledge that seperates a good parts man from a mcd's cashier is not valued by the management of these corporations, good people cost money, and most people are not willing to pay more for a part to have it found by a qualified person, assuming that a computer system can be omnipotent and will always ask the right questions. there is no replacement for knowledge, experience, and pride, it is a vicious circle, you buy things that are cheap and soon your job goes to someone that is willing to work for less.
    you have to pay more for someone to give a ****.
    just my $0.02
  20. blackls1z
    blackls1z Registered Member
    Aug 9, 2004
    30
    Terryville, CT
    Looks like I'm going to have to replace my cable because its doing the same exact thing. I'm guessing its not very hard to replace? What do you have to do to get that thing out of there?
    Colin
