Stiffer Rear End
Discussion in 'The Garage' started by eshorvath, Dec 2, 2003.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    My back end of the 86 K5 sits lower than the front. Any suggestions for suspension to keep her level? Air shocks?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    add more leaves ?
    is truck stock front and rear ?
  3. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    ORD ZERO RATES /forums/images/graemlins/thumb.gif
  4. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    no, 3 inch lift springs on front
    3 in blocks in rear
  5. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    What is that?
    Eddie
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Zero rates /forums/images/graemlins/thumb.gif
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    dont get air shocks! they suck. add a leaf if you want it stiffer, zero rate if you want it a lil higher only. BTW add a leaf usually gives you 2", while the zero rate is 1"
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  9. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Where do you find add a leaf?
  10. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Thats basicly what a zero rate is except it doesn't add to the spring stiffness /forums/images/graemlins/thumb.gif
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    3 in blocks in rear
    UMMMM, if you got a 3" block inthe rear your probley not going to want a zerorate too /forums/images/graemlins/thinking.gif
    Why not use a 4" block, you can find those cheap.
    Otherwise shackle flip looks like it might be in your future /forums/images/graemlins/wink.gif
  12. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    The problem is especially noticabe when i have a load in the back, or my dirtbike on the trailer. What would fix this??
    Eddie
  13. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    How long, and how hard is this flip kit to install? It is 30degrees here. Is this something that I will need to have the truck out of commission for a couple days?
    Eddie
  14. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Here is some info on the install of the ORD shckle flip. install
  15. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    I was looking at that article. Does the time vs outcome make it worth it?
    Eddie
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Eddie
    could buy a 3" lift rear spring too, as far as loads in the back its going to squat no matter what unless you move to a heavier spring. Since you in the same place I am (temperature wise) I would look for a 4" block and call it a day. If you want to help squat get a lift spring it will be stiffer because of arch. The ORD flip will take some time and you will still have a stock spring that will squat under load since its the same rear spring.
  17. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    OK< where did you get the new dash?
    Eddie
  18. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i've got a shackle flip and i like it.much better ride but its a real job getting it on. as far as the squatting goes, when i had a 2" add a leaf from rancho in the back it would hold a load ALOT better. i could hitch a heavy trailer on and it would only drop an inch. without the extra leaf it would sag about 3". the ride unloaded is a little stiffer with it but its not too bad. i think its about 50 bucks for a set. if you dont want it any stiffer definatly go with 4" blocks instead of a zero rate. cheaper and safer.
    For a dash look up LMC truck. they have good prices, but for a new dash your looking at 3 bills and change. or you could do what i'm gonna do and get a dash cap. it glues over the original and is supposed to look like new. its about $100
  19. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    carbon fiber vinyl layed over the dash heated and trimmed, cost less than $20 /forums/images/graemlins/thumb.gif
  20. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    Eddie
    yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes
    i spent 30 bucks (i made my own) and about 8 hours it was DEFINITELY worth it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
