stiffin the front frame
Discussion in 'The Garage' started by TWISTEDJACK, Oct 12, 2005.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I have too much twist in the front frame section from the front cab mount forward. Right now I have a stinger on the front and a winch plate below that. But what could be done in between ?? Tie the cage to the frame under the hood and to the stinger???
  2. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    you could box the frame and tie in the cage
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    how is your cage mounted to the truck? is it mounted to the frame? or to the floorpans of the truck? both ways can be correct, but you may run into problems if you try to tie a bushing mounted cage directly to the frame.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd consider tieing in the cage to the stinger and add a down bar around middle of the engine (on the cage to stinger tie bar) to the frame rail. Only issue there is steering shaft and tire clearance(at stuff).
    But like asked, is your cage tied to the frame? If not you don't want to just tie your front frame to your body.
  5. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Cage is tied to the frame now. I just need to stiffen it up from the firewall forward.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    What I said would be a great way IMO, also running a strut bar from side to side over the engine.
    That is my plan anyway. Except minus the stinger.
