still can't start my 6.2L engine - any ideas?
Discussion in 'The Garage' started by colbystephens, Mar 30, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i got everything hooked up and working properlly, finally, except for the engine itself. :( this is driving me crazy - particularly since i have to drive 1 hour each way to go work on my rig (read: expensive).
    so here's the thing - i'm getting fuel to the injectors, but when i pull the fuel return line which goes back to the injectors, it doesn't have any fuel in it. i re-timed my fuel pump today, as i know it was wrong. i lined up the punch-type mark on the pump gear with the "0" on the outter cam gear. that's correct, right? if that's correct, that's the last thing i should be having a problem with. i cranked the starter for, over a number of trials, close to a minute, maybe a bit more, and still didn't have any fuel in the return line. I would have kept cranking, but over the last 3 days of attempted starts I've killed my brand new batteries, so I gotta get them charged. :( do you think i just need to keep cranking the engine, or is there something else causing a problem?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Obviously gotta be a fuel system issue, seeing as a diesel just needs air fuel and compression to run (I'm fairly sure you've got compression and air, hehe!)
    However, I don't know the first thing about diesels, but a buddy of mine was working on his at my place a while back, and there is a little ditty about how to set the IP timing. It can be found here: http://www3.telus.net/gmc62td/6.2TD_swap.htm
    I have no idea if that is useful at all, but good luck anyways!
  3. bronderslev
    bronderslev Registered Member
    Mar 17, 2006
    21
    denmark
    I know its sounds a bit strange but try to warm up your engine by placeing a eletric hot air fan in the engine bay fore a day or so... and then there soud be some lines there runs from injektor to injektor make sure they are new and thinht...
    claus
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Or just plug in the block heater for a couple of hours before you try and start it. I don't think a fresh 6.2 at this time of year would need that though.
    Rene
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so i no longer have a block heater - the freeze plugs were replaced at the machine shop and they weren't able to get the type which plugs in. so, is the concensus that i simply haven't primed the fuel system properly? if so, i like that. it's easily solved.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
  7. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    sounds like it needs to be bled properly I have the manual on disk for the cucv's if need more info PM me:waytogo:
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Might want to try using the battery in a running vehicle to get it started, instead of using your new batteries.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Cranking speed is another 'essential' for a diesel to start. It has to be spinning fast enough that the intake charge gets real hot as it's compressed. Slow cranking will doom you to a 6.2 that won't start. Mine was a mofo to start right after the swap, which was about 75% to do with the starter I had at the time. I didn't know how much difference a good starter could make until I swapped in a new 28MT gear reduction unit.
    Rene
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Make sure your glow plugs are doing their job. Even a "fresh" 6.2 won't light off without a little preheat. I helped a friend troubleshoot a no start condition on his 6.2 with a brand new powermaster starter and 2 new optima red tops. Believe me, it spun FAST. After messing with it for a long time, I finally checked the glow plugs. Every one of them was open. I installed new ones and it fired right off.
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    He has 8 brand new "Quick heat" glow plugs...
    Rene
