Still having driveline problems.
Discussion in 'The Garage' started by BrownK5, Jan 12, 2006.
  1. BrownK5
    BrownK5 Registered Member
    Jan 8, 2006
    25
    gresham,OR
    Ive been breaking u joints alot lately because i just lifted my k5 6". so today i dropped the t case 1" and grinded my driveline so it has more clearance at the yoke . i also put in a new u joint near the t case yoke. it still sounds like something is going to break every time i take off. what should i do?
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    You need to make sure your drive shaft operating angles are not exceeding a 3-degree difference between the yoke and drive shaft. You can buy an angle finder for only a few dollars. I have similar problem right now as well with my truck, but the problem is not so bad that it is breaking parts. The operating angle of my rear differential yoke and drive shaft is about 0-degrees because the rear lift blocks I am using where manufactured with a 4-degree angle, in order to correct any srive shaft angle problem, but the operating angle at the transmission yoke to drive shaft has a 5-degree difference, which is 2-degrees too much from the recommended max. The only problem this is causing is a small vibration at 15 and 35 MPH. I will probably lower my transfer case to about a 1-inch, and this should solve the problem.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Google on " drive line phasing " " and pinion angle", you can learn all about it.>
  4. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
  5. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    also check your rear tranny mount. mine was broken and i never noticed until i put the lift on. I had a major clunk every time i took off. You also need to verify that your driveshafts are not too short now w/ a 6" lift.
