STILL HAVING TIE ROD PROBLEMS!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rh88k5, Sep 16, 2002.
  1. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    I'm trying to tighten up my 88's frontend before I get new tires, but I cant get tie rods for it! My rods have a short passenger side and long (52 inch) driverside, 2 pieces plus an adjustment sleeve, everyone tries to sell me a 3 piece assembly. I've been told my blazer is not really a k5, but a "V-10" instead, can anybody "steer" me in the right direction to get this part?
  2. codeman
    codeman Registered Member
    May 8, 2002
    42
    Lincoln, Nebraska
    GM changed the name from K5 to V10(only on the VIN #). They are still K5's though. This topic has been discussed numerous times here. As for the tie rod, LMC truck has what you are looking for. People around here told me to get a heavy duty aftermarket one. That is my suggestion.
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    If you take your truck off road at all dont even fool with replacing the stock pieces,just get a Rockstomper rock rod.You wont bend this tie rod and it even comes with new ends. /forums/images/icons/grin.gif
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, what you describe is the same as whats on my 77. Ask for one for a 1977 K5 and take a look at what they bring out. Autozone and Advance auto both keep them in stock.
    Depdog
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yeah, I need to get me one of them! jekbrown just put the rockstomper setup on his 1 ton conversion. It makes the stock stuff look like a toothpick! I couldn't talk him into letting me jack up his truck using his brand new rockrod though! /forums/images/icons/grin.gif
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Iv run into rocks with it and slipped off of rocks and come down on it hard with only scratches to show for it /forums/images/icons/grin.gif Its still as straight as the day I got it /forums/images/icons/grin.gif
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    You can swap to the older style if you want to, but you have to buy the tie rod and both rod ends. If you just want to replace with stuff like you already have, go to a different parts counter or start varying stuff a little. For example, tell them it's an 89 or tell them it's a Suburban until the right parts start showing up. Some of these computer databases get the model year change stuff wrong and sometimes the factory did things a little different. There's no reason why you shouldn't be able to get the parts you need.
  8. rh88k5
    Sep 11, 2002
    94
    Burlington, N.J.
    THANKS TO EVERYONE!!
