Still messing with this cruise control. Please help!!!
Discussion in '1992-Present Chevy & GMC models' started by Bondo, Feb 15, 2003.
  1. Bondo
    Bondo 1/2 ton status
    193
    Bath, NY
    1996 Tahoe. I unhooked the plug at the cruise control module and tested the leads. I am getting all of the signals from the cruise control switch and the brake switch. It's getting ground and power. So I thought it must be the cruise module itself. Got a brand new one, and it still doesn't work. Cable appears to be fine. Now what do I do???
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the cruise must use the vss signal for speed reference, it probably links from the ECM to get the vss signal. could be a problem in that circuit.
  3. Bondo
    193
    Bath, NY
    Thanks! That's what I was sort of thinking. Anyone know how I would check it?
  4. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    go to dealership and see if they can access the com and see whats happening inside there b/c it can have power and ground and everything you can check but have crossed signals or something. You cant tell by lookin at it or sometimes by reading the power and ground with a multmeter. /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif http://bigboytoys.8k.com and www.zombieoffroading.8m.net
