Still not convinced that lift blocks suck?
Discussion in 'The Garage' started by DUKE, Oct 1, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    opps
  2. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    /forums/images/icons/shocked.gif ...What are the detail on that pic? Is that your truck? How and where did it happen?
  3. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I think that is a direct result of the f.o.r.d. factor! /forums/images/icons/grin.gif
    Mike
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Yeah thats definately a ford...let that explain the pic not blocks....
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Just looks like his axle was in more of a hurry that the rest of the truck. That is not lift blocks problem. That is I forgot to tighten my U-bolts problem
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    He might need a bit more fender trimming to get those tires to fit up there! /forums/images/icons/tongue.gif
  7. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Definetly a ford problem he even put the boggers on backwards!!!
  8. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    I have not idea about the details, or if this was a block job or not. I found it on a oopps page somewhere and thought you all might get a kick out of it.
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    OOPS! /forums/images/icons/tongue.gif
  10. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I've seen that pic before. If I remember correctly the picture was taken at a truck show and the truck in the picture fell apart during a car crush attempt.
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I hate to admit that I have some experience with this kind of "oops". Shortly after I had the 388 stroker broken in, I was testing the acceleration capabilites of the Suburban. I hammered it from a stop light, spun up to about 5500 rpm and then manually shifted the TH350 into 2nd. I heard/felt a loud bang and then lots of snapping, grinding and jerking. I skidded to a stop and I could immediately tell something wasn't right. The back of the Burb was sitting way low. The first thing I did was fire the engine, it killed from the violent jerking and bouncing. I then got out of the truck to survey the damage. The 32's were no longer centered in the wheel wells....not even close. I started to pick up the trail of busted parts that lay in the road behind me as other cars were running them over. I picked up pieces of two lift blocks, part of the leaf packs and one shock. I had the Burb towed home (obviously /forums/images/icons/grin.gif ). I ended up demolishing the shocks, driveshaft yoke, leaf spring on one side, brake hose, u-bolts, e-brake cables, etc. I dented the gas tank pretty good(from the axle rotating around and smacking it real good) and rearranged the sheetmetal around the wheel wells. I guess the good part is that this gave me an excuse to lift it.
    Sorry for such a long post but that pic brings back some pretty horrific memories. Now I have some busted lift blocks to show off. /forums/images/icons/crazy.gif
  12. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Just another one of furd's better ideas...adjustable wheelbase.
  13. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I wonder if he's got his boggers mounted backwards because he knows a Furd will never make it through a mud pit -- and will always have to back out. /forums/images/icons/grin.gif
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    in a way butch you are right, but blocks make a leverage boost. so it is probaly a combination of the two.
    but i do agree tighten the damn things better next time and get full springs.
    grant
  15. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Kind of reminded me of the funny car days when we move the rear tires forward to add traction. But I don't remember anyone doing this to a longbed Ford.... Oh that says it all Fuc*ed Over Rebuilt Dodge!
  16. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    The boggers are backwards probably to provide maximum floatation during acceleration. Not necessary with a ford since SH!T Floats anyway.
  17. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    same thing almost happened in my frist gen blazer.the center pin and bottom pin on the lift blck broke and i almost lost the spring pack on to the axle.the block had almost slid out from under the axle and only had about a 1/8 of an inch left holding the springs up.at work took a forklift and lifted truck up from bumper and put it back in place torqed it down and limped it home after work.next day ordered lift springs to never have to deal with blocks again. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
