Still Overeating!!!!
Discussion in 'The Garage' started by hi pinion, Mar 15, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Still Overeating!!!! UPDATE****
    Ok, so far i have changed the radiator, the radiator cap, the heater core, the thermostat , and the fan clutch. :crazy: WTF???? It is stil running hot and boiled over today in the over flow tank.
    I have some questions, first, does anti freeze go "bad" ????? Because its the original anti freeze from when i bought it 1 year ago. I dont know how old the stuff was when i bought it. :confused:
    Also, could a water pump go bad withought making noise and leaking everywhere? :confused: They tell me if it was bad, it would be leaking or making noise.
    I cant figure it out. I just want it to go away. Help please. Any input is good input , later, Jacob
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    well, if the impellar in the water pump was destroyed somehow i guess it could be bad without hearing noise. they arent that expensive, so maybe its worth a shot
  3. hi pinion
    Sep 25, 2003
    5,354
    Also when i say "overheat",,, it never got pegged, but 3/4 of the way hot. It never pegged on the red line,but still overflowing into the tank.
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Could be possible you have an air bubble in there somewhere... I was told to fill the Motor/Rad up with coolant, Through the Thermo housing... just throwing something out there.
  5. hi pinion
    Sep 25, 2003
    5,354
    Has anyone ever heard of a broken or not working water pump , that diddnt either leak, or make noise???? :confused: Also, i went down and got new antifreeze, and i am doing a system flush on it as we speak.
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    How bout the hoses, are they old? Could be one of the trying to suck shut.
    Any water in the oil...head gasket maybe?
    If none of those or the water pump...I'm stumped.
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Had a S-10 that overheated for no evident reason. Was a blown head gasket. 4.3 V6.
    I hate metric!!!
  8. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Jacob, in the past I owned an auto repair shop and was a mechanic before that and I do remember seeing several water pump impeller failures. On several they broke loose from the shaft and on one dirty antifreeze and very high mileage had actually worn the impeller fins enough that it would overheat. Its rare but since you've replaced everything else its worth a shot. Im assuming the head gaskets are ok????
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    im so used to replacing my outboards impeller every year for safetys sake, im thinking it may be the problem. outboard impellers go a lot easier than sb's
  10. hi pinion
    Sep 25, 2003
    5,354
    The hoses look decent. Its only got 87 thou on the motor, i am stumped too. :confused:
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    dude if you put that stop leak crap in there there is a good chance you plugged somthing like a water passage up, i would do that flush, drive it around get it nice and hot witht he flush stuff in it and drain it and flush the whole system out with one of those kits from prestone, i have one in my truck and the mini and i liket hem alot, they work pretty good!!
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    [​IMG]looks like this
  13. hi pinion
    Sep 25, 2003
    5,354
    I dont know how to check the head gaskets, if it is the head gaskets, im basically screwed. Ill have to take it to a shop for that, im ok at the older stuff, but, this is my furd e250 work van i need to use for work. It has all kinds of stuff you need to remove before you can even get to the head gasket.
    Also, does the antifreeze ever get old???????? :confused:
    I just took it out for around 1/2 hr, running the flush stuff in there with ONLY water and the cleaning solution. With No atifreeze, just like it says to do on the bottle, It got warm, just now on the drive , but diddnt overheat. :confused: Its got a damn mind of its own. Also after letting it sit for 5 minutes and idle in the driveway,, (to come in here and make a post) , i went outside and its running way below half on thetemp guage now.:confused:
    Could it be the flush stuff really works? More help please . Theres a few questions in here i need answered. Thanks guys.
  14. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I read a post once where they replaced the hose with a new one and had overheating problems. It turned out that the old hose had a spring inside to keep it from collapsing and the new hose did not, so the hose would get sucked shut at higher rpm's. It would pop back out when you slow down so it was really hard to find the problem. Kind sound familiar? They ended up taking the spring out of the old hose and putting in the new one.
    I hope it's cheap fix like that for ya.
  15. hi pinion
    Sep 25, 2003
    5,354
    THATS WHAT I GOT!!!! :grin: Minus the fancy hoses and junk, i got the stuff in a boltle ( the smaller one) ,,,,,does this crap really work? I mean really, does it? If this does the trick i will be amazed.
    More help please.
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i did the flush on the mini it worked pretty good, but i flush it out once a month anyway as i only run water in it
    Also there is a old hot rodder trick from way back,
    Go to napa get some water soilable oil, and put half a cup in the water, it reduces the surface tension of the water, making it able to cool better
  17. hi pinion
    Sep 25, 2003
    5,354
    Just a hose would be bad ass. :cool1: I wish it was just a hose, everyday the truck is down i loose money bigtime, and thats no good. How do you check the hose anyway? Mabey i can have my wife punch it while i look at the hose? :)
  18. hi pinion
    Sep 25, 2003
    5,354
    Ok so,,,,,,,,,,,
    GUYS, im going to let this thing sit and idle for another half hour, and see if it gets hot. If it dosent get hot,,, does it sound like a hose , or what?
    AAAARRrrr,, dont you hate when you replace all this crap with new stuff,trying to fix the problem,,,, getting all exited thinking " Its going to be fixed this time " ,,, and then let down because it doesnt ? I dont know whats else to do, whats left? Hoses, and what else?
  19. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    I think you would just pinch it.:dunno: It should be the lower hose, and if it has ribs in it, or if you can feel a spring, then it's probably ok. Ya kinda hope it dosent have one, dont ya:rotfl:
  20. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    First look inside the radiator when the engine is idling, bubbles indicate a combustion leak from the head gasket. Also you can check the spark plugs, they will look very clean and have a greenish/whiteish soot or stain if the head gasket is leaking antifreeze into the exhaust port. A good shop can check this with pressure tester as well. You replaced the radiator with a new one right?
    Antifreeze does get "old" or more accurately "contaminated" by rust, dirt and metal from wearing parts. It wont cause the engine to overheat though but will cause the all the metal parts to rust and corrode.
    Was your antifreeze really rusty looking when you replaced the radiator?
