Still running high?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Nov 7, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Not me my blazer........I found out that the wire going to the choke was broken off, so I replaced it and it is still running a high idle any other things that might cause this?It's a 84k5 witha stock 350
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Could be: choke stuck on high idle, bad dashpot, frayed or stuck throttle cable, Vacume line disconnected or leak, Bad pvc valve. Timing to far advanced. The list goes on and on but this is a good start.
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks for the repley....I also sprayed the carb. down with spray and checked the vacuum lines....I will try agian tomorrow
