Still vibratin
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88bblazen, Aug 11, 2004.
  1. 88bblazen
    88bblazen Registered Member
    Mar 23, 2004
    32
    SouthTexas
    My rear end is still vibrating after i got the drive shaft rebalanced the tires balance and rotated. It starts around 65 m.p.h but it will quit after about 15 minutes. I aint got no idea so everyone up for suggestions. /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    What tires? If they are bias ply tires they can run rough until they warm up. Sounds similar to your problem.
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Mine does the same, goes away after a bit. I have 35x14.5x15 TSLs.
  4. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    Make sure your drive shaft operating angle is not too excessive. No matter how well your drive shaft is balanced, if the U-Joints are at too much of an angle, then your drive shaft will vibrate. Spicer recommends no more than 3 degrees of angle.
