Stock 16.5's that will hold the beads
Discussion in 'The Garage' started by wayne, Oct 30, 2006.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I just noticed this today and was not sure if anybody else ever posted this info. I found out that they do have stock 16.5x6.75 rims that will hold the beads just like a 15 or 16" rim. They are M truck wheels. The centers are rivited in and they weigh a good bit more then a civi 16.5x6.75" wheel. The top 2 pics are M truck wheels and if you look close you can see the grooves on both sides for the beads and the bottom pic is a stock civi 16.5x6.75" rim. You can also see the rivits on the M truck wheels and the weld marks on the stocker.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    nice find.
  3. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    i'm leary of 16.5's
    i've read that there is a hump behind the bead on 15" and 16" wheels that are there to help the tire hold the bead. and from what i understand is that the 16.5 wheels dont have this added ...uh "hump". that they are more flat out to the bead and will let the tire back away from the rim.:dunno: oh i just realized you said that would hold a bead, so the m truck 16.5's have this hump, huh. thats what you were saying in the 1st plce, duh:doah:
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    how wide is that wheel? looks a little narrow for big tires.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    :D
    Ira
  6. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    :doah: wouldn't you know I skimmed right over that, right to the pics.:doah:
  7. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    Just a thought, could you take a piece of say 1/4'' round stock and weld it around the rim to in effect create a "hump" of course it would need to be welded and ground down. Hmm I wonder if ive lost my mind or Ijust came up with my next project.
  8. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    i prob wouldn't even put stock down. the hump on 15's and 16's isn't THAT pronounced. a good sized bead would probably be pretty close.
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You could get a 12.5 wide tire on with out to much effort. Might even be able to do a 13.5. I might be a good alternative to somebody building on the cheap. If they are only doing 35's or 37's and on a tight budget these wheels might fit the bill.
  10. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Oh and BTW, I need them without tires. I got them to get my truck in and out of the garage.
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    I suppose you could do something like that. I have no idea if 1/4" is the right amount (probably not). If you have too much material you will never get a tire on the wheel and if you have to little you won't help the bead problem much. IMO, just buy the right wheels/tires in the first place and it won't be an issue.
  12. Txchevy18
    Aug 29, 2006
    225
    Tx
    Ya I know all about the rims not letting the tire fit on. I used to work at discount tire for about two years so I have a decent collection of rims and tires laying around that I just coldnt let got to scrap. I noticed I have an extra set of 16.5 12's centerline alumminum rims sitting in the back and was just toying with the idea. I have a the same size wheel on my truck right now just they are welds in stead of centerlines. Wheels look great but after about 15 pounds or so and quick manuver offroad and youl blow a bead. Ive been thinking about beadlocking them but with out a safety bead it would be almost pointless. Like I said just an Idea, I may grab a spool gun while im on beak at work and try running a small bead around one of my spare wheels and see how it works.
