Stock 1972 Oil Pressure Gauge
Discussion in 'The Garage' started by reecem, Mar 8, 2006.
  1. reecem
    reecem Registered Member
    Sep 23, 2005
    17
    vancouver, canada
    Hey,
    I have a 1971 Blazer with a 1987, 350. My oil pressure seams to always be on the high side even when the correct amount of oil is in the engine. It may have a high pressure oil pump in it but I am wondering what the range of the stock oil pressure gauge is. Whats the middle, low, high, etc.
    Anyone know?
  2. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i have a small block stroker with a new hi volume oil pump in my 70 blazer. my stock gauge is pegged most of the time. it settles to a little past half way while idling after a long highway run. i have an 85 3/4 ton suburban with a stock 350 and it always pegs its oil gauge too. i wouldnt worry about it, i think high pressure is caused by tight bearing clearances in a fresh motor.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    If you really want to find out install a good aftermarket gauge. Thoes old school guages 'wear out'. I thought I had a cooling issue and all along it was my guage...
    .02c
