Stock 1977 K5 Front Shackle Dimensions???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rigdonhome, Jun 7, 2003.
  1. rigdonhome
    rigdonhome 1/2 ton status
    May 11, 2003
    252
    HoosierLand
    Could some fine Person out there give me some dimensions for the stock shackles that came on my K5? Mine have been replaced by some cheap junk that I want to put back to stock and lift properly with lift springs.
    The main dimension I need is the distance from center-to-center from the spring bolt hole to the frame mount bolt hole. The shackle width would also be helpful, but I can probably figure that out closely by the bushing width.
    /forums/images/graemlins/confused.gif
    Cheers,
    Scott
  2. rigdonhome
    May 11, 2003
    252
    HoosierLand
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I wouldn't suggest replacing with stock shackles, they are junk. I have pics somewhere of my stock shackles bent a good half inch to one side. They are flimsy stamped steel and no good for offroading. You can get shackles here
    http://www.hill4wheeldrive.com/ or here http://www.offroaddesign.com/index.htm for slightly more than stock shackles.
    EDIT: also wanted to add if you are lifting the front slightly longer shackles will prevent your spring eyes from hitting the frame during flexing. That's why most aftermarket shackles are 1/2" or more longer than stock.
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The stock length is 4" center to center. If you have 6" lift springs or more then you'll need to add 1/2" to keep from hitting the frame. Using 1/4" plate is stronger than stock, most use 3/8" plate. Stock bolts were 7/16" but many people up to 1/2" bolts with new bushings. Good luck.
