Stock 350 TBI fuel pump enough for 454TBI motor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Oct 15, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am going to be doing my 350tbi to 454 tbi swap in the near future and I am trying to work out all the logistics (BEFOREHAND, for once) so my truck has minimal down-time...I have the 454 TBI motor and I am going to be installing a new cam/lifters, new timing chain, etc...Just freshening it up a bit...Do you guys think I will have to replace the 350 TBI fuel pump with a bigger one? I have the fuel pump for the 454 but I really, really, really, really don't want to have to drop the tank and replace it...If the stock one (for the 350) isn't enough, could I just add an in-line fuel pump deal to take up the exta slack...I figure that Cummins have 2 fuel pumps, why can't I So what do you guys think...
    Chris
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    350 tbi pump will be fine. /forums/images/graemlins/thumb.gif
  3. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    just went threw this issue, this spring.
    if you are adding after market part's to the 454, STOCK 454 pump will not be enough.
    a STOCK 454 pump is barly big enough to run the 454 and under certain condition's isn't big enough for that.
    i put pump's from a tuned port corvette in mine and cured all my problem's.
    i do still have the gm part number's here if you need them.
    pm me if you need them.
    dave
  4. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    if you put a tpi pump in,why didnt you mention how you regulated the fuel pressure?seems like pertanant information,being that tpi is ran at a much higher pressure than tbi.a 350 tbi pump will have no problem with a tbi 454 engine.a 350 and 454 pump run the same pressure,but the 454's injectors flow more.count on that.rob
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well, both pumps may be capable of the same ABSOLUTE pressure, but are they both rated at the same gph, or flow-rate? Somebody tell me that they are pretty damn close cuz I really don't want to dro pthe fuel tank...And wouldn't the stock fuel press. regulator take care of the TPI pump's high pressure...doesn't the reg. just direct unused fuel back to the tank....
    Chris
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 350 and 454 pumps may produce the same pressure, but at what volume? The flow rating at a given pressure is important, as a 454 at 5,000 RPM will need a lot higher volume of fuel than a 350 at 5,000 RPM.
  7. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    Just taking a '90 pickup for an example, the Delco replacement pump listed is the same part number for the 454 and the 350.
  8. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    So instead of dropping the tank and going through all that rigamaroll, could I just add a little in-line pump to take up the extra slack?
    Chris
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That's good info! /forums/images/graemlins/cool.gif So the pump for the 350 is over rated, probably so GM has to keep one less part number in stock. /forums/images/graemlins/wink.gif
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I vote for dropping the tank. I had the 31 out of my 89 in about an hour, and thats with the skidplate too
  11. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    79,im glad you mentioned that,i thought they would be the same part#,but i didnt want to open my yap till i was sure.i do know that a buddy has dont the swap twice with no probs.if there was fuel starvation,you would know.rob
  12. captain chaos
    Mar 29, 2002
    413
    i regulated the fuel pressure with turbo city's regulater that came with there tbi. /forums/images/graemlins/cool.gif
    dave
