stock 350
Discussion in 'The Garage' started by jayccb, Jun 1, 2004.
  1. jayccb
    jayccb Registered Member
    Dec 26, 2003
    18
    wisconsin
    I'm looking at replacing my engine and am trying to figure out if I should go with a crate motor or just rebuild mine. I want to increase the hp by at least 100 hp. Can I just change the heads and cam shaft of mine without changing everything else? I've never done a rebuild and of course money and time are issues. Can anyone help?
    Thanks /forums/images/graemlins/k5.gif
  2. chevyalltheway
    chevyalltheway Registered Member
    May 16, 2004
    12
    if you have the cash i would get a crate moter. if not make sure you at least check the bottom end of the moter you are rebuilding. ive seen alot of moters that have self destructed cause of the horse power increase with worn out rod and/or main bearings. just some things to think about.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    In that case you may want the crate motor approach. It is no fun running into problems on your only transportation ( been there , done that ). It isn't hard to rebuild an engine, but some machining may be required if it is real worn. Some tools will also need to purchased/borrowed, like ring compressor etc.
    It is very fulfilling to see it run after doing it yourself though. /forums/images/graemlins/k5.gif
  4. buckshot33
    buckshot33 Registered Member
    Jun 1, 2004
    12
    Bakersfield CA
    Im gonna have to agree with this. 100 hp gain is a pretty healthy gain and will take some planning to achieve. just drop a 350 or 383 crate motor in it but nothing with too much cam. you don't wanna lose any of your low end.
