Stock ABS Drums to Disk Brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lance, Jul 31, 2002.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I just purchased a 14 bolt for my rear with a disk brake setup in place. According to the specifications table, my '90 came with rear ABS (anti-lock brake system) on the 10-bolt from the factory. I think I know what it takes to hook up the disc brakes, I just want to know how this will effect the ABS system, if at all. Will the rear disks act like the ABS drums? /forums/images/icons/confused.gif
  2. dyeager535
    26,975
    I would have to say that it would, unless the ABS sensors were at the wheel/drum, instead of the carrier. (center section) If ABS sensors were at the wheels (IIRC, early S-10's with ABS in the rear were this way) then if you removed the sensors, or what they read, it *should* kill that system.
    I also seem to recall that K5 (V10, whatever) ABS systems had something else hanging off of the Master Cylinder/brake lines up front....
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    1st.. I'm jealous! My 14 came with drums!
    I put an 80 under my 91 sub with the rear-abs.. and no problems whatsoever. As i understand it, the 'anti-lock' sensor is in the rear of the tranny (and confirmed by my 90 service manual).
    Only issue i've had is the pedal seems to go further down than before. Plenty of braking power.. just 'lower' than I'd like.
