Stock Alternator Output
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Apr 24, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Anyone know what the stock alternator on a 84 k5 with a 305 puts out at idle? What's max output? Thanks.
    Brian
    <A target="_blank" HREF=http://84k5.coloradok5.com>http://84k5.coloradok5.com</A>
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Roughly 60 amps.
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Is that the max or at idle? I'd like to know both if possible.
    Brian
  4. Waxer
    1,857
    Long Beach, CA.
    that would be max, idle I have no idea. You'd have to hook up a multimeter to test it out yourself
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    stock alt should be about 70 to 90 amps... it probabaly only kicks out about 40 or so at idle... as he said you can get more exact numbers w/ a multimeter.
    1987 Chevy K5 Blazer- 350 TBI
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    And keep in mind all these figures are only accurate if your alternator is in good shape- If the brushes are worn down, you'll get even less.............
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't hook your multimeter inline with the alternator feed unless you want to watch the meter smoke. Most can't handle more than 10 amps. [​IMG] You need a pretty serious meter to be able to measure the output current of an alternator. A lot of parts stores have a rig they can put your alternator on to test the output voltage and current at various RPM's.
