stock axle ratios
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86blazerk5, Aug 10, 2000.
  1. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    Can anyone tell me what the stock axle rationis for an 86 10 front 10 bolt, and for a 79 rear 12 bolt, and weather or not they match? I really would like to know if anyone can tell me. Thanks!
    Ike
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Yes they match and did yours come with a factory tow package?and if you have a 700r4 most have 4.11 or 3.73 if not they had 3.08.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    There are many different axle ratios available for both years. You will have to check the specific axles that you are looking at.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    You can easily figure it out by jacking up the back end and counting the number of wheel revolutions compared to driveshaft revolutions. The front and rear are always the same or else you would rip up your tires and drivetrain in 4WD.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Or pull the covers on the and look for the gear ratio stamping on the Ring gear(it will be a number like 41:11), if there is not one, you can count the teeth on the ring and pinion.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You can also looke at the RPO codes in the glovebox but someone may have changed the ratios. I dont remember the codes but I think GU6=3.42. Someone will post them. If you have an auto you will probably have 3.42 3.73 or 4.10 if you have a manual you will porbably have 2.73 or 3.08
    90K5
  7. 86blazerk5
    Aug 9, 2000
    387
    ok, I have the 700r4 transmission, however my glove box tells me I have 3.42s and a locking differential. i dont have the factory tow package, at least I dont think, i have a tow package, but i dont think its factory. I still need to look at the donar 79 and see what it has on it to see if we have a match or not!!! Thanks guys!!!
    If you can afford it, do it. If not, find a way!!!
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    The donor '79 will <font color=red> probably </font color=red> be 3.08's. Your 86 has overdrive so the 3.42's are pretty common. The 79 would not have overdrive so the 3.08's were pretty common. I would pull the covers off and make sure, if you're going to swap difs this would be a good plan anyways.
    Rene 81 Jimmy,350,SM465/NP205,FF14 bolt,HD Dana 44,3.73's,4"susp.,35"Grabber MT's,body in progress
  9. k5beast
    k5beast Registered Member
    Aug 1, 2000
    8
    Northwest Florida
    Pull covers and count teeth on the pinion and ring gear, then divide the number of teeth on the ring by that on the pinion. This will give you the true ration of the axle.
    The Beast, feed me a Jeep!
    79 K5 project
