stock axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelnut46, Mar 27, 2002.
  1. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    The specification link in the technical section of this site states that the specs are for Chevy Blazers only. I'm curious if anybody can tell me what axles are in my 77 GMC Jimmy? It has a 350/350 and the sticker in the glovebox says it has 3.07 gears.
  2. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    be more specific with your question. what axles? go outside and look down, those are the axles. just kidding, but what about the axles do you want to know?
    if they are orig they are the 28 spline, but if they have been upgraded then the only way to tell is pull off the diff cover.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    They should be the same axles listed for the Blazer. If you think they have been swapped, compare the pumpkins on your truck to the ones in the axle I.D. in the technical section. I think they should be a 12 bolt, and a Dana 44 on a 77. Don't quote me, but I don't think they had switched to the 10 bolt front in 77. So those are probably your axles.
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    They kept the 12 bolts up to about '80 or '81. I'm pretty sure all '70's model Blazers/Jimmy's get the 12 bolt in the rear.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    My 79 has a 12 bolt rear and a 10 bolt front. They stopped putting D44 in blazers and jimmys in 78. So yours should have a 12 bolt rear and D44 front. I'm almost 100% positive that blazers and jimmys had everything the same throughout 73-91.
  6. MudbogAD
    Jun 29, 2001
    672
    My 79 Jimmy has a 12 bolt rear and a 10 bolt front. They stopped putting D44 in blazers and jimmys in 78. So yours should have a 12 bolt rear and D44 front. I'm almost 100% positive that blazers and jimmys had everything the same throughout 73-91.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend's '79 C10 has a stock 10 bolt rear.
    They started using 10 bolts when they ran out of 12 bolts and D44s.
