stock caliper bracket -- 14b FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kxt, Mar 2, 2003.
  1. kxt
    kxt Newbie
    Feb 28, 2003
    4
    I've been using the search feature for what seems like hours. So far I've found many 14bFF axle disc brake conversion threads. There are many brackets out there but has anyone tryed using the stock caliper bracket off a D44 front. I'm going to be getting the calipers and lines off of amy junk axle and want to make my own caliper brackets for my 14B
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I can't think of a good reason to make your own when the aftermarket practically gives them away...the brackets (with hardware...) run from $65 and up.
    Trying to modify D44 brackets to work correctly on a 14 bolt rear is probably gonna turn out half-assed...and this is your brakes we're talking about.
    Rene
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've gotta agree with Rene. Why reinvent the wheel? All of the brackets that can be purchased through members of this site are tested, abused and proven. No reengineering needed. /forums/images/graemlins/thumb.gif
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    just spend the money, they are cheap. just think about how much you are worth. even for a person who works for 5hrs an hour. i am sure it's gonna take over 12hrs of surfing, looking for parts, cutting, welding, etc. multiply that by 5 and you are at 60. that's just on time. then comes electricity, gas, busted nuckles /forums/images/graemlins/frown.gif /forums/images/graemlins/angryfire.gif, cuts /forums/images/graemlins/mad.gif, and parts you'll use.
    spend you time wheeling /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif and fixing broken things... /forums/images/graemlins/smile.gif
    that's how i see it.
    ARQ
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think ORU's kit is exactly this. They take a K20 front bracket, redrill it, and use a spacer.
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    And charge $900.../forums/images/graemlins/eek.gif
    Rene
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, they do, and...
    And charge $900...
    ...also true, for the standard calipers and not the e-brake calipers. /forums/images/graemlins/eek.gif Adding e-brake calipers will add another $600 to the fee. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Anyways, I had some stock K20 plates laying around and sent them off to Bill (45acp) whom redrilled them to the 14FF flange bolt pattern and made me some 1 1/4" spacers that were necessary to get the proper clearance to run the calipers.
    These are exactly like what ORU sells. Only I got mine done for a fraction of the cost...let's say it was real cheap! /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  8. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    the calipers.
    Where do these spacers go? Got any pictures of the setup? I used the front Dana44 back plates for my 12B discs and they work great, so I will be using some sort of the same idea for the 14FF... $$ are short ya know! What are the K20 plates? Like D60 stuff? Or D44 stuff?
    Mike
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    The spacers mount on the flange first with the backing plate sitting on the spacer with the bolts going thru to the threaded ends on the flange.
    K20 plates are identical to K10's but just slightly larger around in diameter. /forums/images/graemlins/thumb.gif
  10. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I did find out that the 14bff DID come with disc brakes from the factory on the RV body (I think its a P body). I don't have my service manual close but I can verify if you want. From dealership the brackets are $650, who know what a yard would charge, if they even had one.
