stock comp ratio 454 tbi?
Discussion in 'The Garage' started by big_truxx, Jun 25, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    What's the stock comp ratio of an 89 tbi 454? If it makes any difference the original motor in an 89 crew dually scotsdale model :D
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    comp ratio
    It's probably in the neighborhood of 8-8.5:1. I can look into it further to get you an exact number.
  3. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    that sucks. I was hoping it'd be up around 9 :( I know gm's specs for the 350 mr goodwrench was 8.5. I may have to rebuild the whole motor anyway so mightbe good to up the compression some :D 10:1 would be about right I think :D
  4. LongIslander26
    Jun 25, 2005
    256
    Big Block rebuild.
    Zero deck the block and use flattop pistons, a thin head gasket, and watch your cam lift, that should get you in the ballpark.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    7.9:1
    230hp @ 3600 rpm
    385ft/lbs @ 1600 rpm
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I am thinking since it has 163k on it and was ran hot and quite possibly needs head gaskets, may as well tear it down and put a couple other parts in the rebuild when I can afford. I just played with my desktop dyno 2000 and with pocket porting and large valves, 10:1 comp, headers, summit 1300 cam, and with the 660cfm setting using dual plane setting for induction it brings up roughly 425hp and 500 lb ft tq.. :thinking: :dunno: doesnt seem like that little work would produce that much power but... I dunno.
  7. LongIslander26
    Jun 25, 2005
    256
    454
    10:1 CR is going to require some high octane gas in Maine close to sea level, especially with a low duration cam which will raise your dynamic CR . What's the cam specs on that summit cam?
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    yer right. I forgot about that. :waytogo: Just ran a different parts list of 8:1 comp ratio, heads pocket ported w/ large valves and headers w/ the stock cam option and its up to about 325hp and 470 lb ft tq :D now assuming that in overheating the rings and all are still ok, that would work out very well w/ the stock tbi setup :)
  9. LongIslander26
    Jun 25, 2005
    256
    454
    Looks like a stump puller to me! :saweet: :woot:
  10. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    Brand: Summit
    Product Line: Summit Camshafts
    Cam Style: Hydraulic flat tappet
    Basic Operating RPM Range: 1,500-4,000 RPM
    Intake Duration 050 inch Lift: 208
    Exhaust Duration 050 inch Lift: 218
    Duration at 050 inch Lift: 208 int./218 exh.
    Advertised Intake Duration: 266
    Advertised Exhaust Duration: 276
    Advertised Duration: 266 int./276 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.475
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.500
    Valve Lift with Factory Rocker Arm Ratio: 0.475 int./0.500 exh. lift
    Lobe Separation (degrees): 112
    Intake Valve Lash (in): 0.000
    Exhaust Valve Lash (in): 0.000
    Computer Controlled: No
    Quantity: Sold individually.
    cam specs :D
