Stock D60 yoke with bolts ASAP
Discussion in 'Parts & Trucks Wanted' started by clarkjw24, May 12, 2006.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'm in bad need of a front 29 spline D60 yoke from a chevy. I'm needing it before next weekend. Bolts and strap or ubolts a plus. 1310 ujoint I believe.
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i just pulled one. pm me with shipping info. :D
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I too have mine, I dont know where the straps are though. If sweetk30 falls through let me know
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Pm'd you sweetk30.
    Branndon, thanks also.
  5. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Send me a GameCocks hat and I'll send a 29spl yoke, even swap!
    .......man , I'm late again!
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    What kind of hat you want my friend. Primary color? Logo or "Name". PM me your address and I'll send you one anyway. As long as your yoke is a chevy 29spline even swap. I'll need a spare.
  7. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    Will do!
    Stock front D60 has a 29spl. 1310 correct?
    I also found two 1350 yokes off D70 rears, I think? They have the same cap dia. as a 1410 but are about 5/16 shorter? I think that all 1350 yokes had the sheetmetal straps also.
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    How many hats for all of them?:D
    BTW:sweetk30 money sent.
  9. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    I think I better hold up on the 1350 yokes! I'm going to be using HAD shafts and I might need one or both.
    I think Jessie uses a 1410 at the pinion and 1350 CV at the case , but I'm not sure. I would like to go 1410 all around with no CVs just so I only have to carry one type spare joint and two different extra yokes.
    I will be PMing some info to you.
    Jeff
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have a yoke that was installed but never used on a rear D60.(basically brand new) Do believe it is a 1310 and uses u-bolts. Let me know if you're interested and I can get pics.
