Stock draglink on 6" lift FYI
Discussion in 'The Garage' started by 88K5Jimmy, Jul 31, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Stock draglink on 6\" lift FYI
    When I installed my 6" lift I used a 4" raised steering arm and a 2" drop pitman arm. I was always under the impression that the draglink had to be parallel to the ground. So I ran it like that for a year with a lot of bumpsteer, thinking I couldn't do anymore for the bumpsteer than crossover. Then a friend told me I need the draglink parallel to the spring not the ground and I read that on here in a search. So anyway, I took out the 2" drop pitman arm and installed the factory pitman arm and guess what.........
    No more bumpsteer, at least in the neigborhood (which on some streets I had bumpsteer). So a year of wacko bouncy steering was fixed in about an hour. If only I had known /forums/images/graemlins/waytogo.gif
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Re: Stock draglink on 6\" lift FYI
    That's what I found out too.
    /forums/images/graemlins/thumb.gif
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Yep, that's one of the threads I was talking about.
