Stock Front Shock Setups - 4 vs.2
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BJarvis354, Aug 3, 2002.
  1. BJarvis354
    BJarvis354 Registered Member
    Jun 17, 2002
    58
    New York City
    There is no information in the specifications page on this and I can't find anything on Google, so here it goes...
    I gather that the additional front shocks were optional and controlled the axles movement front to back...Is this true? Does anyone know what the RPO code is for this?
    I imagine this would stiffen the front and not allow as much articulation, hence be undesirable...True?
    The reason I am asking is I think I got some front suspension problems, and the shock are my main suspect. I am going to go it cheap and get some Gabriels for now (as recommended elsewhere in this forum...) and hopefully fix the problem. I know I got only two right now the RPO is F51 : SHOCK ABSORBERS, FRT & RR, HD
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    OK, the code in my glove box says 1Z75 and says "Front Quad Shocks". I dont know if this was there because of the trailering package or what.
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    this does stiffen the front a lot, i had the quad setup, and removed a set and get better articulation, and a much softer ride.
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I believe it's there to stop bounce when loaded.
    My truck came with the plow package. Included with this plow package is the quad shocks (RPO 1Z75) and heavy duty front springs (1F60) among other things.
  5. BJarvis354
    Jun 17, 2002
    58
    New York City
    Thanks for the quick info guys! I do not have that setup and think I am thankful for that...I really do not tow that much besides the occational trip with ny brothers 20' checkmate. /forums/images/icons/grin.gif
    Brady
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    I'm kind of glad I have them. The front doesn't wallow or bounce like with a single shock design. I could use some new front springs though..
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The actual reason that the truck came with dual shocks was to reduce shock fade. Both shocks together are supposed to be rated as if it was a single shock. If some one said that they had a rough ride, they must of put two regular shocks next to each other.
  8. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    i was the one with the rough ride, and it requires 2 different shocks because of length.
    i forget teh brand i used, but they were about$60 each, and used what were listed
    for my app by the makers, but it makes sense to use a much softer pair, and they
    couold act as one reg shock, but 1 quality shock does a good job and its cheaper
