Stock fuel gauge work with new tank?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by roostr3269, May 14, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I cant seem to get the fuel gauge to work with the new tank installed. Is there something i am missing or any ideas? The tank is a 31 gallon from a '98 blazer along with sending unit. Thanx in advance.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Duno about your tank but I bought a tank from NWMP and the stock gage does work fine with their sending unit!??
    mabie a ground wire is missing or something like that??
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i am using the stock guage and a 31 gal tank from an 84, check your grounds.
    ARQ.
  4. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Seems like the tank/sender won't make any difference to the gauge as long as the operating range is 0 - 90 ohms like stock.....?
  5. roostr3269
    Jul 2, 2001
    305
    michigan
    Yeah, i rechecked the grounds and they're good. Maybe somewhere in all the parts swapping, i screwed up the gauge. I guess I will do some more checking, thanx for the replies.
  6. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I'm having the same issue on my 71. I have a brand new sender and tank from LMC. My stock gauge only reads about 1/4 tank when the tank is full. I haven't really looked into it yet, but assumed I have a bad ground. If I solve it I'll let you know...and if you find the problem, please post it!
    Thx, JT
  7. roostr3269
    Jul 2, 2001
    305
    michigan
    Sounds good, I am still trying to find the problem but nothin yet.
  8. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    roostr, did you try your sending unit bebore you put it in the tank? I hooked up a long ground wire on mine and made sure it worked before I put it in the tank. ZZ, are you sure your float is not hitting the side of the tank? I guess i`m lucky, I built a 38 gallon tank and a friend gave me a sending unit for a school bus, International part , and it works perfect with the stock gauge.
  9. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    how hard is it to swap out the tank to a larger one? A buddie told me that ramchargers had a big tank... Are 80's chev blazer tanks bigger? How hard are they to swap out?
  10. roostr3269
    Jul 2, 2001
    305
    michigan
    No i didnt, but i wish i did check it before i put it in, dohhhh!!!!. As far as the tank install, it fit just about perfect. It was a square 28 inches, so it fit perfect between the framerails. Maybe i better pull it and check her out, thanx.
  11. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    They have a newwer style fuel sender that I bought for my big rig. It doesn't have the normal float but a long tube and the float is inside. they make different length tubes depending on the size of your tank. If they make one for our trucks you would need to know the measurement in inches from top to bottom of your tank. I don't think there's anything in it that would be a problem using it in gas not diesel.
