Stock Fuel Lines
Discussion in 'The Garage' started by Calclips, Aug 27, 2003.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    What size are the stock fuel lines on an 81 K20 with a 350? I bought an in-bed gas tank and need to know what size lines I should buy (rubber) to run down to the frame and meet up with the stock hard lines down there...
    Almost ready to start flogging the hell outta my /forums/images/graemlins/truck.gif...
  2. Calclips
    Apr 4, 2001
    1,005
    Someone knows.... I can feel it....
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I don't know where the fuel lines ar located on your truck, but I would run metal line if I were needing more than 12". Metal line is easy to bend and compression fittings are cheap.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Most likely is 5/16" for fuel. Doe's this have return line's?
  5. Calclips
    Apr 4, 2001
    1,005
    The truck may or may not have return lines, I have yet to look into that. I don't have the little metal hard-line bender, so I was going to run some rubber fuel line down to the passenger side frame rail and connect it to the existing fuel lines that run there. This setup is temporary for this winter only, I'm gonna go flatbed when I finish my next term at school (October-December).
