Stock gear ratio?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Dieselmh, Aug 3, 2001.
  1. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Does anyone know what the stock gear ratio should be in my 1970 K5? Was there a stock ratio, or was it by choice? I am trying to buy a 14 bolt FF from Brian, and am trying to decide if 4.56 gears are too low for my stock TH 350 tranny? I don't want to top out at 45 mph. Thanks.
    Matt.
    Diesel
    Everything's bigger in Texas!
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Mine came with 3.73 in 72.......
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Ditto, my 72 has stock 3.73s.
  4. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    likewise
    1972 K5
    1991 Jimmy
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The '70 will have 3.73s if it was a 6 cyl., or a 307. If it was a 350 it will have 3.07s, unless the lower gears were special ordered.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  6. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    for the most part the stock gear ratio is 3.73 for a manual trannie and 3.07 for an automatic. I noticed in my options book that you could order 4.11 gears but this is a rare option.
    '72 blazer 9" lift YOKO mudders 35x12.50 350/sm465/3.73 UTAH
  7. Blazer1970
    1,600
    Old Mission, MI
    As I stated above, the stock gear ratio was determined by the motor, not the tranny.
    <a target="_blank" href=http://wsphotofews.excite.com/035/Aj/MB/kW/Y918729.jpg>http://wsphotofews.excite.com/035/Aj/MB/kW/Y918729.jpg</a>
    Tim
    87 Burb 4X4 350
  8. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    yes like blazer70 said if it was a 6 or 307 it will have 3:73s if it was a 350 it will have 3:07s........ unless specail ordered diffrently (check the sticker on your glovebox)
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, edelbrock performer intake+carb, MSD pro billet http://communities.msn.com/68K10
