Stock Gearing GM 10-Bolt
Discussion in 'The Garage' started by prossett, Dec 2, 2005.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    What is the stock gearing on a 1983 Jimmy GM 10-bolt?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    It really depends. You can look in the glove box and get the RPO code to find out what is stock. It's always possible it could have been changed through the years if you bought it used.
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    there are many different gear ratios... from 3:08 up to 3:73 it seems from the factory. best thing to do is pop the diff cover and spin the tires till u see the numbers on the big ring gear. then.. use this chart and you could easily figure it out
    http://www.pavementsucks.com/forums/viewtopic.php?topic=56143
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Heres what was offered with what drivetrains . Bear in mind some strange combos can , and did , come off the assembly line . Just depends on who pushed the order through .
  5. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    i had a factory v8 with 3.42 in late 70s . that chart is good idea but not exactly true. thay help but dont forget the assembly line factor.
    bet 3.08 as most i have seen.
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Im betting 3.08's if its a TH350. Woo-Hoo!!!
    If its a 700R4 I'm guessing 3.73.
    Now wheres my magic 8 ball?? :haha: :haha: :haha:
  7. dyeager535
    26,980
    FYI on the drivetrain combos: they are EPA certified and there is no way that anything other than a certified combo came off the assembly line for anything other than experimental vehicles.
    That doesn't mean that printing errors were not made and you can't find service manuals or brochures that show things that weren't available, or don't show things that were produced, but the rule is, EPA certified or it didn't exist.
    That is MUCH more prevalent on the later stuff because emissions controls/CAFE got extremely strict (compared to the 60's for instance) so offering huge varieties of ratios, transmission, and engines doesn't make sense from a cost standpoint on multiple fronts.
    I know it's neat to think that some cooler than cool combo came off the line (454 K5 for instance) but it just couldn't happen.
