Stock height 1/2 vs 3/4 tons?
Discussion in 'The Garage' started by bablazer73, Mar 31, 2004.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    What is the difference in height between say a stock 1/2 ton and a stock 3/4 ton pick up? I trying to decide what to do with the 89 blazer i am getting. Primarily a daily driver but it will have a plow on the front. I want the truck to be lifted 2" over stock. I have a 3/4 ton 4x4 parts truck and was thinking of pulling the 3 leaf front springs out of that and putting them into the blazer. I know the 3/4 ton truck is taller, but don't know by how much. Or should i use the stock 2 leaf and go with an add-a-leaf. ride quality is NOT an issue. I figured that i would use what i have available instead of buying.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have both a 1/2 ton and 3/4 truck, both are 83 and both are long boxes and both 4x4. the height is exactly the same.
    there only one thing though my 1/2 ton was a heavy half (6050 GVW) and the 3/4 ton is a light 3/4 (6200 GVW)
    all the other trucks ive seen 1/2 or 3/4 are all the same the difernence is 2wd and 4wd
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i just put one leaf in the front and it lifted it about two inches on a 1/2 ton.still have those leaf packs. /forums/images/graemlins/grin.gif i would assume a 3/4 ton is at least 3 in. higher on average. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    oh yea my dads 85 blazer has the 3 leafs up front and his is the same height as my 3/4 with 2 leafs
  5. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    so putting the 3/4 ton springs would be a waste. Only stiffer, no taller.
    Well that sucks. now i gotta spend money!! I hate that!
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, his blazer rides extremely stiff.
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I don't really care if it's stiff. I only drive it to work and back. A whole 7 miles. Family outings are usually in the wifes truck.
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    could you shackle flip the back and put some of the rear 3/4 ton leaves in the front to make a spring pack?
