Stock Horse Power from a 400?
Discussion in 'The Garage' started by 78Blazer, Jun 25, 2003.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    Just wondered if anyone knew or knew where I could find out what was the stock HP rating and tourque on a 78 4 bolt main 400???
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    165HP and 210LB/Tq IIRC
    hyrrah for the smog motor 70's /forums/images/graemlins/rolleyes.gif
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Actually, I believe that is 175 hp. /forums/images/graemlins/wink.gif
    -Harrison
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It's massive is'nt it. /forums/images/graemlins/rotfl.gif
    That's the old s.a.e. Net rated horsepower, actually it's quite a bit higher.
  5. 87BrnRsd
    Apr 21, 2003
    2,457
    So, does that mean that my 87 is actually making a lot more than 210 hp??? And if you know, what is the torque on a 2 bolt main 87 350?
    -Harrison
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wasn't gross HP the "old" way of measuring? That was when they tested "stock" engines on a stand with no accessories, open air cleaner, tuned headers with no muflers, etc. Then the manufacturers started measuring their stuff "as installed", with a stock air cleaner, water pump, alternator, etc., stock manifolds, stock exhaust system, stock mufflers, etc. This is net HP and is supposed to represent real world numbers. They started this change somewhere around 1970 or so, and it still continues today. So that sad 165HP can be directly compared to todays stuff that's coming off the assembly lines. /forums/images/graemlins/cool.gif EFI has made it possible to produce excellent power, driveability, and still have ultra-low exhaust emissions! /forums/images/graemlins/thumb.gif
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Yepper's, that's how it was rated, I think all it did, was help with Insurance rate's.
  8. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    400 4 bolt main blocks were only avalible in 1970-72. The 400 if it is the correct year 1n 78 would be a 2 bolt. Two bolt 400 blocks are alot stronger and better cause the 400 4 bolts have weaker bolt/clamping force on the main bearing caps cause they drilled the outer bolts into water jackets. I've seen three engines that some circle track boys ripped the crancks out of the blocks. My .02 cents /forums/images/graemlins/thumb.gif
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yeah and a 2 bolt can easily have a splayed kit added to it for much more strength. But with a 400, your pretty much limited by stroke to staying under 6000 rpm anyhow.
  10. dyeager535
    26,975
    20% is a pretty good correction figure. Add 20% to that number and you've got gross. All thats good for is comparing it to any pre '72 published numbers.
    Which 87 350? Carbed, TBI or TPI, and which application? /forums/images/graemlins/smile.gif Don't get stuck on 2/4 bolts, more than anything that was related to application, not power output. For instance, I'm gonna go out on a limb and say that MOST 350 truck engines are 4 bolts (I know there are some that aren't, just guesstimating that more than 50% are 4 bolt), which make a decent amount of torque, but are designed to move a lot more weight around. Of some of the later SBC's (early 90's?) only the Corvette (in cars) was getting a 4 bolt main block, while the camaro's making just a bit less power, were still using 2 bolts.
  11. 87BrnRsd
    Apr 21, 2003
    2,457
    That 87 350 is in my K5, with tbi. Thanks.
    -Harrison
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    -Harrison
    175 net hp is correct for those 400 cid 4 barrel truck motors.
    And 1972 was the first year for net hp ratings. The same truck 350 that was rated at 255 gross hp in 1971 was rated at 175 net hp in 1972.
  13. dyeager535
    26,975
