Stock idiot light to stock gauge conversion on an 87' K5
Discussion in 'The Garage' started by tocsin, Oct 23, 2004.
  1. tocsin
    tocsin Registered Member
    Dec 31, 2003
    11
    Stock idiot light to stock gauge conversion on an 87\' K5
    Hey all.
    I have an 87' K5 with the stock idiot lights in the dash. I see the full gauge clusters going for nothing on ebay from time to time. Has anyone tried to do a swap? And if so, what all was involved?
    Are the lights just ran by an on/off circuit or are they fed by a sender with some logic behind it? Think it'd be worth it to pick one up and monkey with it? Possibly going to a junk yard to snag stock senders - or easer to just go with an Autometer cluster?
    Thanks!
    Will
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Re: Stock idiot light to stock gauge conversion on an 87\' K5
    Idiot lights are a on/off circuit. Gauges use either resistance or dc current.
    Oil Pressure-Take out the switch and swap in a pressure transmitter, hook one wire to it going to the guage.
    Volts-Hook to ignition sourced battery.
    Water Temp-Remove plugstat(Temp Switch) and install a temp bulb, one wire to guage from bulb.
    All part besides gauges can be picked up for cheap at your local autoparts store. The hardest part will be messing with the dash/wiring.
  3. tocsin
    Dec 31, 2003
    11
    Excellent, thanks BigBlock. That info really helps!
  4. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    No Problem, Just remember that the stock gauges may not be as accurate as some aftermarket gauges. If your going for a stock look, go ahead with stock gauges, it would be a good idea to check their accuracy with another gauge to check the wiring etc. If stock looking isnt important go for the aftermarket gauges.
