Stock K5 Transfer Cases any problems?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smartpatrol, Feb 10, 2002.
  1. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    I am replacing my 305 in my K5 with a high torque engine (500+ c.i.d). I was wonder if anyone has had any problems with the GM transfer cases and big engines. Do they hold up pretty good?
    I thought my Computer hobby was expensive......
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I would think that a 500+ ci engine would tear apart the stock transfer case in no time flat with any ammount of wheeling. I would guess that a 205 would hold up.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Seeing that you have an 83 K5 you probably have an NP208 Tcase. I wouldn't run a 500 inch motor threw a 208, your asking for trouble. Get an NP 205 Tcase and you should be ok. I have a NP 208 in my truck, and I know I wouldn't want to realy on it with a 500 inch motor in front of it.
    My Chevy isn't broken, its just out of gas.
  4. smartpatrol
    Feb 6, 2002
    86
    Ault CO
    are np205's common? is it something i could find at a junkyard?
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Yes and no. It depends on the application as in what transmission you want to mount it to and the number of splines on the input shaft. Check this out... <a target="_blank" href=http://www.offroaddesign.com/NP205tech.htm>http://www.offroaddesign.com/NP205tech.htm</a>
    When all else fails... Check the blinker fluid.
    78 K-5
