Stock Proportioning Valve Ques
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wakedog, Dec 6, 2001.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    My rear brake arent working at all and the red brake light is on on the dash. It has happened before and it was low on fluid so i would add and they would be fine and the light went off. They probably need to be bleed(and they will this weekend) but where is the switch on the prop valve?? And i heard the switch will reset after they are bleed, true or not true?? Thanks
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  2. wakedog
    Mar 7, 2001
    233
    Minnesota
    come on
  3. NE79
    NE79 1/2 ton status
    Mar 10, 2000
    177
    Nebraska City, NE
    Not sure, but mine's been doing that for 3 years now. Sometimes there's stopping, sometimes not. Kinda scary.
    uh-oh
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I am not a brake expert but it is POSSIBLE that the master is worn out and bypassing. It will not have enuff pressure to turn off the lite, and can be intermittent.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    There is a button on the front of the prop valve that needs to be pushed in to bleed the rear brakes. I use a dowel cut to fit against the rad. support. The light should go off as soon as the front and rear pressures are equalized. If you know you have air in the rear lines you might want to start bleeding at the prop valve and working your way back.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  6. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Disc brakes activate almost immediately when applied. They ride very close to the rotor. Drum brakes activate slower because they ride farther from the drum. One of the things the proportioning valve does is to delay front brake engagement slighty to give the drums time to contact. Of course the valve also sets the brake bias. (typically 30% for each front tire and 20% for each rear) Lastly there is the sending unit which makes the brake light turn on when there is uneven front to rear bias. It sounds like you may have a rear slave cylinder leaking. The switch you need to press on the master cylinder is on one end under a rubber cap. This will allow maximum brake fluid to the front brakes when you bleed them. In theory, if you start with the rears, and bleed them good, you won't need to push in the switch when you do the fronts.
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Goose is "on the money" here; thats why it's really called a Combination Valve. It's my understanding that the button only needs to be depressed when Pressure Bleeding, and is not neccessary (to depress) when manual bleeding. Yes, I would make another attempt (or 2) to bleed the brakes to extinguish the light. If it continues to return your master cylinder is need of replacement/rebuilding.
    Real trucks don't have spark plugs!
  8. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    i had the same problem with my brakes and could not get them to bleed manually. I had to get them power bled to reset the prop valve
    Bigmeats
    1975 Blazer
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What method did you use for bleeding? Did you try bleeding the front or rears first? The reason I ask is I had done countless manual bleeds (with a helper in the rig and me yelling to them to step on and hold the brakes, me cracking the bleeders, closing the bleeder, yelling back helper to take foot off brakes, having them pump them up, and repeat until no air was detected), starting from furthest away from prop valve to closest, and never had a problem. I'm wondering if we do it differently, or if I have been lucky.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  10. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    I had the same problem on my truck. It turned out that the Master Cylinder was not holding presure. I changed it out and I haven't had a problem since.
    See Ya,
    Keith
    <font color=green>Born to Drive My K5</font color=green>
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
