stock pump vs. agr super pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefjerky, Nov 27, 2001.
  1. beefjerky
    beefjerky Registered Member
    Feb 14, 2001
    64
    it is time to replace my power steering pump. is the agr super pump worth the money? does it really perform better than stock? or should it be replaced with a stock unit?
    thanks
    rob86blazer
  2. beefjerky
    Feb 14, 2001
    64
    c'mon!!! all i need is a couple opinions!
    thanks
  3. Blazinit
    Blazinit Registered Member
    Nov 26, 2001
    29
    Minnesota
    Well it does say "Super" on it...does that help? Sorry, I haven't had the luxury of upgrading my power steering pump yet, but I'll definately put it on that Christmas List that was going around here today:-) Good luck to ya!
    '84 K5 Blazer 4"Rancho R/B w/Quad Diamond Back front 350/TH700r4/NP208/35" BFG AT/10 bolt F&R
    Washington, USA
  4. CK5
    May 19, 1999
    21,625
    702
    CO
    You can upgrade the pressure of your stock pump: <a target="_blank" href=http://westtexasoffroad.homestead.com/powersteering.html>http://westtexasoffroad.homestead.com/powersteering.html</a>
    Steve
    Director of Global Expansion
  5. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    You can also rebuild the stock chevy pumps without much trouble at all. Then do the mods that Steve showed you and you are done for just the price of a rebuild kit at NAPA.
    See Ya,
    Keith
    <font color=green>Born to Drive My K5</font color=green>
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  6. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    I replaced mine with the ARG pump and steering box and it made a huge difference in the effort to turn the wheel and shortened the number of turns required. The problem I ran into is that I decided to do much more serious work including a D60 front axle. Now when it all goes back together I will need to go back to a 2 wheel drive steering box for cross over steering. It was a major waste of money doing the ARG thing in my case.
    <font color=red> Bill, "Shop Rat" </font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Shop-Rat>http://coloradok5.com/gallery/Shop-Rat</a>
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    That's what I was going to say: The AGR pump is obviously just a modified Saginaw pump. They are probably not doing anything except using a new fitting and valve and covering it with paint. This is stuff that you could do without opening the pump or even taking it off the truck!
    However, doing this will increase the assist on and off road. These trucks are valved pretty light already. That is part of what some people perceive as bumpsteer, too. You hit a bump and the wheel turns so easily that you inadvertantly turn the steering wheel. Modifying your pump like this will make this problem worse.
    The AGR pump and box are meant to go as a pair. The box has a different gear ratio, like what you would find in a car, with fewer turns lock-to-lock. The added oil flow helps to compensate this. Plus, this gear must be valved pretty light. If you knew what you were doing and how to set up the gear, you could probably get the parts from a couple of old gears and make one of these.
    For a rock ram setup, modifying your own pump would definately be a must, because the added volume of the ram would require a lot more oil flow. But I would use my existing gear and just attach some fittings to it in front of and behind the piston.
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
