Stock q-jet on Edelbrock intake
Discussion in 'The Garage' started by Zooman, Apr 2, 2006.
  1. Zooman
    Zooman Registered Member
    Jul 10, 2000
    35
    Ontario Canada
    Hey guys I have put a stock q-jet on my 78 Chevy 4x4 with a 350.
    I have a edelbrock intake on the motor now and I am trying to hook up the throttle cable using the stock throttle cable bracket and it seems the throttle cable is a little short now. Do you guys use some sort of throttle cable extension to make it work or do you not bother using the stock throttle cable bracket?
    Let me know what you think.
    Matt
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I used a zip tie :o
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    what intake do you have? and are you trying to use the bracket that bolts to the rear 2 bolts of the intake? you may need to get the bracket that bolts to the back 2 bolts of the carb. i did that on my TA. i used a bracket from an 84 K10.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah my stock '85 bracket works with Ede 3701.
  5. Zooman
    Jul 10, 2000
    35
    Ontario Canada
    Eldelbrock intake
    Hey guys I have a eldebrock intake on my motor. I am trying to use the throttle cable braket that came stock on my 78 and its also the same as the one of my 82 c10. The bracket has one botle hole that goes on the very back bolt of the intake manifold and one bolt that bolts just behind the carb as is flat on the manifold.
    Does the 84 use a different throttle cable bracket?
    Matt
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no worries, i enjoy repeating myself. :doah:
