Stock Ratio on a power steering box
Discussion in 'The Garage' started by adamforsythe, Feb 5, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What is the Stock Ratio on a power steering box fore a 1986 K5 Blazer??????
    I'm thinking of getting a new one that is 12:1
    Adam
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I believe it is 16:1
  3. dyeager535
    26,979
    12:1? That'd be something like 2 turns lock to lock IIRC. "High performance" GM cars had ratios like that.
    At higher speeds that would probably be fine, but at low speeds that is probably going to be pretty darn hard on everything. (you, pump, etc)
    What's the reasoning?
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I want to replace it. I know my gear box is hurting so is my power steering pump. I just found that on summit.....so I need to look for one that is 16:1.
    Adam
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Most GM truck steering boxes are variable ratio and IIRC they go from 16:1-12:1.
