Stock Rear Springs vs. Tuff Countrys
Discussion in 'The Garage' started by MudFlap, Apr 21, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    Does anyone know how the stock rears off of a 89 blazer and the 2", or 3", or 4" tuff country springs compare as far as flex goes. The tuff country website says that the spring is 405lbs/in is that right? What is the spring rate on my stock springs. I would like to get rid of my blocks but I don't want to sacrifice flex and a soft ride.
    Trey
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I pitched my rear springs for a set of TC's and have never regretted it. The stocker's with blocks was a sh*tty ride and mediocre flex... I am pretty sure they were just wore out and worthless. The TC's are real nice and soft, they flex very well for me... though if I were to do it again, I would go with a 2" lifted TC spring for the ride quality and an ORD shackle flip for the lift.
    Just my .02
    -Ryan /forums/images/graemlins/k5.gif
  3. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Currently I have a shackle flip and 4" blocks, but I am thinking of using a longer shackle and lift springs. so probably around a 3" spring is what I am looking for.
    Trey
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    How do you compare 89 springs to New ones ?
    How do you compare two year old used spark plugs
    to new spark plugs?
  5. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    What are you talking about? Yes they are old springs, but I am just looking for some advice. This is not any kind of exact info that I am looking for, just some help.
    I figured that someone on this site went from their stock springs to tuff countrys. So then that person should have some good info on how to compare the two.
    Trey
    Trey
  6. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    I just went from stock springs to the 3" Tuff country Ez Ride's. They look great. I haven't ahd a chance to try them out yet but so far they seem good. Wayne was able to flex them a little by hand.
  7. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks, it seems like they will be a soft spring, let me know more when you get to try them out.
    Trey
  8. Executioner
    Feb 22, 2000
    1,530
    Ok, yes they are rated 405. The stock ones are rated lower
    in the range of 200-300.
    As is you will get more flex out of what you have now
    (shackle+4"block) then lifted spring+shackle.
    Good luck
  9. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    F150 spring swap is proably the ultimate for rear spring flex.
    Be careful though, older worn spring shave been known to break under heavy application.
