Stock Rev limiter on a 90 or what.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GRINCH, May 29, 2003.
  1. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Went racing this past weekend at our 3 day Rally and half way down the track (300 Ft.) the engine dies. It feels like a rev limiter or running out of gas. So the second run it does it again and I let off and put it back to the floor and same thing.
    I was running in 4 lo. My specs. 90 Blazer, 96 350 Crate with Vortec Heads. Edelbrock Multi Port Fuel Injection, MSD Pro billet distributor, MSD box without rev limiter, I also have a newer fuel filter on it. I did have my tach disconnected so I don't know the RPMs I was running at.
    I ran this same track last year with the same set up and did well.
    I still ended up with second but the drop outs are making me wonder what is happening???
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    my teacher would say yea, weak valve springs, that is the rev limiter, i will be honest, i got pissed one time and did a burnout and i have a tach and it is connected, got it up to 5500 rpm and held it there for 5 seconds, i wasnt happy, i felt bad after doing it, but i dont think my truck has a rev limiter. and i think the computer might limit it, but im not sure. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    My truck just starts sputterin and missin when it gets above 5k. I think its because of the weak top end that is only rated for 4500 RPM
  4. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    TTT..
    It didn't just sputter.. It was like I took my foot off the gas but I didn't.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I don't think they had rev limiters but your spark plugs and/or wires and/or coil can cause it to fall on its face. It doesn't seem like you've got any of the original electronics anyway with MSD taking care of your ignition and the Edelbrock MPFI taking care of the rest...
    It could be your valves floating but this is highly unlikely with stock Vortec heads in my opinion unless you're running a wild cam. I have valvesprings from 1984 with .020" shims under them and I've taken my motor past 6,000rpm a few times (tach only goes to 6k). I get nervous at 5500rpm (because of the antique valvesprings) but sometimes you have to put rice in its place. /forums/images/graemlins/grin.gif
    Oh, and your fuel pump could not be providing enough flow at 6,000rpm at the rated pressure. At that speed you'll need about 30gph which doesn't seem like much but the instantaneous demand of fuel can cause a pressure drop which will make it fall flat on its face.
    I'd try to get it to do it again and immediately slow down, turn it off, and pull a few spark plugs. If they look cooked then you're probably running out of petrol.
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i did that when i got mad to lol..kind of hard to burn out in my truck though..either an auto..but iv made hast going down the street befor when i wasnt so happy lol..
