Stock rim size and back spacing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bwoodard, Mar 19, 2002.
  1. bwoodard
    bwoodard Registered Member
    Oct 29, 2001
    43
    Chicago, IL
    what is the stock rim size from chevy (I have a 86 Blazer) 15x? and what is the back spacing. I want to put 33" tires in stock rims. Will these fit with out a lift kit?
  2. dyeager535
    26,979
    Well you could get at least 15x7 or x8, maybe even x6 at some point in time, but 7 or 8" is the typical. The code on the wheel, stamped in near the valve stem, is how you tell (or measure with tire off : ) Code will be something like "JJ"
    Already posted on another thread that I know for a fact that 33x10.5R15's fit on stock wheels, no lift, and the optional 3/6 leaf front/rear springs.
    Most shops I've talked to said they'd mount the tires and let me test for rubbing before purchase.
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Stock steel Rally's are 15x8 with 3 5/8 backspacing
