Stock roller cam on a '91 350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91K5, Oct 16, 2001.
  1. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Stock roller cam on a \'91 350?
    Hey guys,
    A friend of mine insists that my '91's 350 came with a roller camshaft setup from the factory. I can't find much info to confirm or deny this, so I was wondering if one of you can shed some light on this for me. I did see a rebuild kit for a '91 350 truck motor that said "not for roller cam". Was it a option, or was this just for high perf car motors?
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Re: Stock roller cam on a \'91 350?
    Negative, the TBI truck motors came with hydraulic flat tappet cam shafts. In '91 only the TPI(vette and camaro) came with roller cams.
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    My '92 Camaro (305 TBI) came factory with a roller cam. I dunno about the '91 truck 350's though [​IMG] ........ sorry, not much help I guess
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Your friend is wrong, it is a flat tappet.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    TPI's came with roller cams and tbi came with flat tappets. So he is half right.
  6. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Also, to add insult to injury, the 350 in trucks were 2 bolt mains! Except for the bigger trucks, which had 4 bolters and steel cranks, but I believe only in trucks bigger than one ton.
    ken
  7. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Not true, from '87 on 3/4 ton and up had 4 bolt main blocks. Cast or steel crank depended on the transmission behind it usually but not always true.
