Stock spare holder
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Broke84, Aug 7, 2005.
  1. Broke84
    Broke84 Registered Member
    Mar 10, 2005
    42
    VA
    Silly question - will a 33 fit on the stock spare carrier for an 84 (the bracket that mounts to the right rear tire hump.) I've been carrying a 31" spare, but I'm replacing my rear tires and will probably use one of the old ones for a spare.
    If the 33 will fit, anyone in VA interested in the 31 (just the tire)? It's not new, but would work as a spare or daily use for a little while. It's free, just give it a ride. Otherwise, I'll toss it. Thanks.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    no the 33s dont fit.. well... and they are heavy enough to break the stock mounts and fenderwell
    I fabbed my own up reinforcing the stock locations with welded in plate... it didnt budge a spec even during hard off roading
    cam
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you run the tire backwards , it fits good enough , and tight enough to work , it will list to the right side a little since the wheelwell is in the way at the bottom . I run stock steel 15x8 rallies .
    I haven't had a bracket crack yet , have seen some that did . Extra bracing may help , as well as changin the bracket from top mount hole to carrier with flat stock .
