stock spring rate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazinaire, Mar 26, 2002.
  1. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Just for s&g what is the sping rate of the stock front springs? It seems that my ez-rides actually ride smoother than stock.
  2. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    With my Suburban I measured and checked them. The spring rate (2 leaves) must amount to about 520 lbs/in. That is not too rigid, But I think the problem is situated with the short spring travel.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I doubt the factory springs are that high, but I think the TF ez-rides are either the same, or alittle softer than factory. 520 lbs/in is what Rancho and Pro comp springs are at (520 lbs/in). I have Ranchos on the front of my burb and they are alot stiffer then factory.
