Stock Stall Speed
Discussion in 'The Garage' started by CHEVY 4WD, Mar 11, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Well thats it Im asking the stock stall speed(tq converter) for a 84 700R4
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I think it is 1500-1600 RPM
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Would going to a 2000 stall make much difference?
    I dont want to spend to much more on gas and I dont wanna heat up the 700 to much either I know before I do it I need a shift kit extra deep tranny fluid pan and a big tranny cooler
  4. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Why do you want to change the stall speed???
    The only reason you really need change the stall speed is if you have a cam that requires a higher stall speed to get it in its power band.
    The stock stall is best for all around use. Espically 4 wheeling. A higher stall just generates more heat.
  5. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    550
    Wasilla AK,
    I have a 2400 stall lock up converter in my K10 it acts just like a stock converter once it locks up expensive though cost me 450 dollors and yes 2000 stall would make a big differance /forums/images/graemlins/truck.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you want a cheaper alternative to aftermarket converters, check out a stock converter from a similar year Corvette. Their stall speed is in the 2,000-2,200 RPM range for quick, hard launches off the line. /forums/images/graemlins/cool.gif
    One from a Camaro or Firebird might also be higher, but I'm not sure about those.
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I dont really know much about stall or tq converters so any info yall might like to give me about them will be appreicated btw what dows lock up mean?
  8. yellowK20
    Dec 26, 2002
    7,601
    550
    Wasilla AK,
    Well normal convertors slip alittle bit a lock up convertor slips just like a normal convertor until a certain point were it locks solid that's the best way I can describe it which isn't very good /forums/images/graemlins/truck.gif
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Kinnda sorta like sliping the clutch on a 4speed?
    So does 2000RPM stall sound good for a 700R4 with 35's and 4.10's on a truck that can be used as a DD
  10. yellowK20
    Dec 26, 2002
    7,601
    550
    Wasilla AK,
    Yeah kinda like that I have 4.88 gears and 37" tires on my stepside with a700r-4 with a 2400 stall lockup converter and it's was my daily driver till I got my other truck 2000 stall would be about right. what do you have done to the motor ? /forums/images/graemlins/truck.gif
