stock suspension, sway bar removal
Discussion in 'The Garage' started by 78Suburban, Jan 1, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I don't have lift, and I'm probably going to keep stock suspension for quite sometime. Right now I'm only going to run 33x12.50's. I have toyed with the idea of upgrading to some bigger tires in the future, and still keeping stock suspension. I'm not afraid to :hack: at all. I know when I flexed out my pathetic stock suspension in the past, it found the front bumpstop pretty quickly. SO:
    Will I see any noticable performance (flexing) gains from removing my swaybar with my stock suspension setup? How hard is it to do? How much weight will I loose? Will it get tipping in high speed mud manuvers?
    thanks,
    James :bow: :bow:
  2. fordtruggy
    fordtruggy Registered Member
    Dec 30, 2005
    55
    Red neck ville Rapid city SD
    No it wont get tippy and it all weights prolly 100 pounds all together if your lucky and yes the flex is better and worth the time.
    I dought there is even ONE true 4 wheelin rig on here that uses a swaybar except some comp buggys use swayaway.
  3. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Because you're near the bumpstops, your compression will not change much. However, you will get more droop. You will probably find your shocks limit this. I'm guessing the swaybar weighs about 35lbs. I was able to easily carry it around with one hand. You will notice more sway when turning. Be careful to avoid extreme swerves at high speeds (i.e. interstates, etc). More trimming will probably be necessary. But, you will find the ride improved.
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    If it is a daily driver, an ORD swaybar disconnect is what to go with. I did this on my burb with 4in. lift and love it!
  5. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Fordtruggy is right, you won't see many non-bling 4X4 with sway bars. I think they were developed as a crutch for independent front sus. With a SFA (solid front axle) you already have leverage from the opposite side when leaning. It may feel more like boating at high speeds but its worth it in flex. I had ORD disco, too much work. Then I figured I'd run it week to week and take it off preparing for an OR weekend; it takes a session of push/pull, on your back etc., not. We leave it off. Now towing is a different story.:bow:
  6. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    Dude, dump it. One of the easiest and best mods (and FREE too!) around. I agree with Doug -- about 35 pounds or so, takes two bolts to remove. It might feel like the front end wants to "push" a little more when cornering, but let's face it -- these suckers never exactly set the bar on cornering performance anyway. TAKE IT OFF!!
