Stock tach with HEI
Discussion in 'The Garage' started by TONYP, Sep 16, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    my tach reads way to high with the HEI. will it work with it or do I need a new one? I have one wire running to the tach from the HEI, and the other wire runs to the + batt., anyone seen this or is my tach a goner /forums/images/icons/crazy.gif
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    THe GM tach harness has a resistor inline on the wire from the tach to the dist, do you have this? I've also had my tach become very erratic with charging system problems.
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Tony,
    You need to build this:
    This is the schematic to cure the high tach readings with HEI and a stock tach.
    Enjoy! /forums/images/icons/cool.gif
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Is this for a vehicle that orignally used points? Because my 79 K10 Doesnt use this setup. It just has 3 wires: power, ground and direct hook up to the HEI tach slot.
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    The schematic is just a (factory) filter that appears to have been starterd in '81 or so. Earlier models didn't seem to have them. I believe Tony has a '72 that used a different style factory tach that was used with points.
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    it is a 72, so it did work with points. Going to make one up and see if that does the trick.
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    Greg,
    Have a guestion on the "15 MF", the guy that put it together put in a "15 MFD" But hes not sure what the 15 MF is. Wnats to know if it's a passive or ceramic relay. Not sure if I'm tell you the right things or not so if you need more info let me know.
  8. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Tony,
    Those parts are capacitors....usually rated in Farads. The smaller values will be in Microfarads (MF or MFD are both acceptable abbreviations), or the REALLY small ones are PicoFarads (PF, PFD, or sometimes called "puffs" by the E.E. Guys! /forums/images/icons/grin.gif )
    Neither are relays....I think he may be asking for the type of capacitor you want....ceramic is one style, there are other types also. I don't know enough about the materials to know which is BEST....it may just come down to the power rating it's designed for, and the accuracy (1%, 5%, 10%)????
    I know for resistors, those are some of the considerations....with "caps" I suppose it's the same deal.
    Sorry I can't help more....I'm not an Electrical Engineer. I just saved that image the last time this post was answered, since I figured someone else would need it! /forums/images/icons/cool.gif
    I chickened out and bought an MSD ignition and Autometer tach so solve my accuracy problems........ /forums/images/icons/tongue.gif
  9. Michael
    1,576
    Sherman, Texas
    Just stick in whatever 15 micro farad you can get...this is just a filter...no need for tricky parts.
