stock tie rod or rock rod??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Apr 22, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I am putting in a D44 and the tie rod is bent pretty good. This is probably a dumb ?, but should I just get another tie rod from the bone yard or spend $70 (I think) and get a rock rod. Is this for rock crawlers only? Anyone on here using one of these. Thanks
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I just put a rock rod on mine... I don't have near as much wheeling experience as others on this board. The rock rod didn't really change the way it drove, and in my opinion if I can spend and extra $70.00 and not have to worry about fixing it again then thats what I would do... That is also what I did... [​IMG]
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    On a d44 (at least mine... 1/2 t0n) it has the one super long one and of course it was shot on my axles when I picked them up... it cost mucho denerio because it's huge... so I say why not pay the same amont for the rock rod... I'm either using the one in my truck now or gonna go rockrod.
    1987 Chevy K5 Blazer- 350 TBI
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I run a home made job on mine, but for stock (we recently replaced them on the '89 Sub), Pep Girls had the best price by far, and they were Perfect Circle (Dana).
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If the design is anything like the one on my 10 bolt, which has the drivers side tie rod end attached to the long part of the tie rod, instead of a seperate end, sont' get a tie rod from a junkyard. There is a 100% chance it is worn out. IMHO - that is like buying you oil at a junkyard....no offense - I've wanted to say that for a while[​IMG] I'd recommend Moog parts for steering parts and balljoints - they are the best
    90K5
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I would definately recomend the Rock Rod.. I haven't gotten mine installed yet, but it definately is worth the money just by looking at it!!! They have jacked up the front of a truck with one on it without bending it.. I have gone through too many and hopefully this will be the last one I buy!
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  7. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Another trick if you have a stock one in good condition, is to take a piece of angle iron and weld it to the stock one to stiffen it up. You may run into a problem if it has the hole for the steering stabililer, though. Mine is 1-1/4", .281 wall DOM tubing with (I think) 1-1/2" x 1-1/2" x 1/4" angle welded to it. If memory serves me correct, the heims are 3/4 thd. with a 7/8 hole. I just drilled out the taper and used the appropriate sized bolt.
    Pete
  8. doonjumper
    doonjumper 1/2 ton status
    Mar 9, 2001
    948
    Visalia, California
    I put mine in last week and one of my buddies told me if you break a drive line you could use the rock rod to get home. We laughed for days on that one. Only $87 delivered plus $20 for the the right end and $32 for the left.
