Stock tow hook positions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Feb 25, 2001.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I have an 88 K5, are there tow hooks i can bolt to the frame with the stock bumper. I think i have seen them somewhere.
    <font color=red>1988 Chevrolet K5 Blazer, Middletown, NJ (07737).</font color=red> wkeil@home.com
  2. Boondock
    Boondock Registered Member
    Jan 29, 2001
    35
    Annapolis, MD
    I have an 86, wanted to know the same thing. I could have used some tow hooks this weekend when i sunk up to the gills in black, smelly mud. blast! please let me know if you get any help about where to mount them.
    The only easy day was yesterday.
    Second place is a body bag.
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Me too. I have an 86....
    "I love the sound rice burners make when ya run over them"
  4. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    they were a stock option they bolt to the frame under the bumper Ill take pics tommorow I think I have an extre set .
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  5. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    There are two different styles ( three if you count the M1008 & M1009 as stock) of stock tow hooks. The old style-a big "J" shaped hook, and the new style-this one has some strange bends in it. I have been told they are both rated at 10000 lbs, but the newer style seems to bend when realy pulled on. BTW the M1008/9 uses square tubing and clevises. To mount the old style just drill two holes in the frame at about a 30 deg angle and add two 1/2" grade 8 bolts. If you need more help just look at the truck you are steeling them from or I can take a pic if you want.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Not sure what year they changed, probably around '80, but the mid 70's won't bolt onto an '83. They look similar, but the bolt spacing is different. My '83 has one "J" shaped hook, and our '89 Sub has two of the more curved ones. Anybody else have a problem breaking the lower bolt on their's?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I just went to a junkyard and found a truck that still had the factory hooks that matched the hole spacing on my truck. I got the J-style and bolted them on with some mongo-sized grade 8 bolts, backed by large washers to help spread the load on the frame.
    The newer style hooks certainly don't look as strong as the older J-style hooks.
  8. Grim-Reaper
    7,385
    Atlanta
    DO NOT SIDE PULL. you WILL bend the frame if you pull from the side. Pull in line with the frame only with those style.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  9. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    pcorssmit, the hooks changed when the front bumpers changed. I am not 100% but I think the bumpers changed when the front clip changed. That was in '81.
    Jim '80 GMC
    Freedom First!
