Stock Tow hooks
Discussion in 'The Garage' started by broncoman6524, Feb 1, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    stock tow hooks suck.
    normally the "U" of the hook is pointing straight down.
    :doah:
  3. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    I bent mine all to crap. They are pretty weak. They make a good back-up, but someting with a closed circle is better if your gonna be doing a lot of pulling or being pulled.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Thanks for the pic. I've tried to tell people in the past that the mounting system of factory hooks suck... and that my friend broke one of the bolts from his and it trashed his bumper... but they all didn't believe me.
  5. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    If you are going to use the stock ones the '73-80 are a much better choice.
  6. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Amen! The 73-80's are twice as thick and mount straight, unlike those weird 81-91 things. Yes, a CUCV-style shackle is better, but the early hooks are pretty good.
    -- A
  7. divorced
    Jul 20, 2004
    5,115
    Don't they mount straight up and down, meaning the bolts will still shear off?
  8. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    No, they are mounted at an angle so the crappy stock frame doesn't rip out.
    dremu is right the CUCV one are probably the best choice.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I used the factory tow hooks on the front of my '90 K5 for years in the original position and never bent them, even after having my truck buried up the bumpers and two other trucks hooked to it. I now have the same hooks mounted differently on my winch bumper with no issues, including pulling out a non-running 7,000 lb. truck on 42's out of a deep rut (two 12,000 winches hooked to the front could not pull it).
    On my factory setup there were 2 bolt holes in the frame with a backing plate on the backside. I have personally seen aftermarket style hooks bent straight, but never an OEM Chevy. In fact, several guys in our club have gotten Chevy towhooks and mounted them on other rigs. The nice thing about them is that the hook is fairly large so it's much easier to hook up straps to it.
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    The stock tow hooks are fine for normal use. If you're gonna pull hard or snatch, hook one end of your strap to each hook and the middle to whatever you're pulling/getting pulled by. In my experience, the bolts holding them to the frame are the weak link. Make sure you're using quality bolts and that they're tight.
  11. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    tow truck drivers like the stock hooks as well, lol
  12. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    Im a bit confuse do you mean hook each end up of the strap to each hook and pull from the middle? of hook up on one side and i guess run it through the other hook?
  13. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Here's mine, hella beefy :thumb:
  14. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    my stock tow hocks r pretty good hit a stump with one of them and it lifted my k5 up in the air didnt bend the hook but bent the tip of my frame up ward by about half an inch
